sleepe3 wrote:And while your at it put in a larger fuel tank breather. I ran mine down the drivers side and into the tyre well to a fuel filter then out the bottom.
David
That should get you some nice petrol smells inside the car as you corner left!!!
The correct venting for the non-emissions (older style) set up always has the actual vent pipe up and over the instrument cluster so it's the highest point in the system, then down the LEFT side of the car and out through a slot to the left/under the tank.
Taking a vent straight down the right side is a problem because the filler and breather are only about 50mm higher than the tank, so when you corner left the fuel sloshes up the filler and breather and out the incorrect vent!
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
