type3lover in the garage...
796 posts · joined Feb 2005 ·
I'm working on a 68 Beetle and trying to get the horn working as it did from the factory - that is, with the horn ring instead of the pushbutton that someone has put in.
The article http://www.wolfsburgwest.com/wired/wired_12_00/wired_12_00.htm is not much help unfortunately. I can't see any plastic bush or connection for the horn wire to go.
I have a wire running down the centre of the column and attaching to the steering box. I assume this should be ground?
I also have a brown wire which when earthed to the body it makes the horn work. I assume that this is the hot wire from the horn. This is currently connected to the push button with the other side to earth.
If I touch the two wires mentioned with ignition on the horn works. That's great, but where is the brown wire supposed to go?
I am also fitting an aftermarket steering wheel in the process but the owner really wants the horn button back where it should be - on the steering wheel!
There are no slip rings etc, but I think this applies to later models.
Please help - I have been pulling my hair out all morning and there's not much left! :cussing
Cheers, T :thumb
