Mick058 Custom Title Time!
1,580 posts · joined Jan 2008 ·
Supposedly there used to be a product you could use to put ontop of your rear shocks and adjust your ride height with it?
Has anyone heard of these or used them before.
Comments/thoughts?
Brad Wolfsburg Elder
3,764 posts · joined Aug 2002 ·
Craig Torrens 6 times Australian, 7 times State Hillclimb Class Champion
8,040 posts · joined Jan 2003 ·
mm nope the 180 kit went on the spring plate and up to the engine cage. I t was not for an on road car.Mick058 wrote:what happened to the "A 180 kit" This may be the thing. Supposedly it used to be made back in the day but they no longer produce them.
So if it sat on the shock tower, it would sit above the shock absorber itself - these are adjustable?
im told you bolt it in over your existing shock absorber and that it can be adjusted.
If you only want to go up and inch then the Custom Vee Dub Coil Overs will do that for you in the back of a Beetle. They will also stiffed your ride a little bit.Mick058 wrote:i only want to go up about an inch. It was a shop that recommended this option. I'm in the middle of moving (house hunting at the moment with temp accommodation) and i have no tools. Shop said this was a cheaper and good option.
Any thoughts on that? Do the coils do anything bad to your ride feel?
