Skip to content
Aussieveedubbers
Headlights not workng on low Beam
Share Share on Facebook Share on X Share on Reddit
DylanTheDubber Custom Title Time!
1,252 posts · joined Jun 2009 ·
#889302
Can any1 have any suggestions?
can any1 tell me out of the wires that connect to the headlights what wire goes where?
1972 superbug 1302
From Dylan
AA003 Custom Title Time!
1,189 posts · joined Oct 2011 ·
#889304
Dylan it's easy.
White is high beam 'cause it's the lightest.
Yellow is low beam 'cause it's not quite as bright.
Grey is for parking lights 'cause it's the dullest.
Brown is for earth 'cause brown is earth colour.
I've gotta look after the Port Macquarie blokes!
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!😂
#889306
Thanks Mate! (:
I'll remember that now and sort this shit out this arvo. I Have a bad earths so im going to run better earths and also change the terminals at the bulbs cause they 35 year old and cracked.
From Dylan
Ldog Commited Dubber
70 posts · joined May 2011 ·
#889313
if you have a kick switch on the floor make sure your wire are not loose!!!
1915,c95,44's,44x37.5,NA, DuBwAy
Joel Now containing 100\% E-Wang
9,368 posts · joined Feb 2006 ·
#889319
Hey Dylan, is the relay still bouncing around unsecured?
Make sure none of the wires have come off.
beetleboyjeff Custom Title Time!
1,790 posts · joined Feb 2009 ·
#889327
Dylan, the boss is away this weekend - if you still need a hand then, give me a holler.
From your ole' mate Jeff
1303Steve Scirocco Rare
8,650 posts · joined Aug 2002 ·
#889339
Hi Dylan
This might help, also make sure the bulbs are working, the low beams do the most work and most likely to fail.
1 attachment · Log in to view
#889386
Thanks Guys!
The Headlight relay is sitting in stock possition but has wrong terminals they dotn lock into fuse holder so ill check everythink i should be able to find the problem.
and okay Jeff Thanks!
From Dylan
vw54 Administrator Always Waiting 4 Friday
16,723 posts · joined Aug 2002 ·
#889390
Start at the headlights have you mucked with the wiring
I read it on FACEBOOK so it must be true
http://forums.aussieveedubbers.com/viewtopic.php?tid=91278&page=1#pid848630
http://forums.aussieveedubbers.com/viewtopic.php?tid=63561&page=1#pid624099
http://forums.aussieveedubbers.com/viewtopic.php?tid=4832&page=1#pid452603
http://forums.aussieveedubbers.com/viewtopic.php?tid=60650&page=1#pid574409
#889405
Okay,
No i havent butthe terminals and wires are original and 37 or sumthing years old so previous people coulda mucked wiv it. The RHS had voltage drop and problems but the wires and terminals were replaced so now its probs time for the left side to do the same.
From Dylan
