Skip to content
Aussieveedubbers
Ignition Questions for 1600cc Super Beetle
Share Share on Facebook Share on X Share on Reddit
DylanTheDubber Custom Title Time!
1,252 posts · joined Jun 2009 ·
#890775
I Bourght new plugs today for my 1600cc TP but they are NGK brand and i have heard sumthing bout not to use them because they go bad with allot heads or sumthink?
And i checked in the owners service manual and only bosch and champion was recomended??
Also whats the best leads to use?? or what do you find good?
From Dylan
68AutoBug Beetle Restorer - Experience over 138\% - YIKES --
11,654 posts · joined Aug 2002 ·
#890805
Hi Dylan
NGK are OK ... same as Bosch..
I wouldn't use Champion in My lawn mower.. lol
Use never seize on the threads or Moly grease etc to stop the steel spark plugs from interaction with the alloy heads..
I've always done this, even with new cars and never had any problems with the spark plug threads..
- Helping keep Air Cooled VWs on the road - location: SCONE in the Upper Hunter Valley - Northern NSW 320 kms NNW of SYDNEY---
69bug Officially Full-On Dubber
300 posts · joined Jan 2012 ·
#890809
What do you recomend lee?
1969 1500
#890837
hi again Dylan
the spark plug leads sold by most VW shops have wire in them
which was the original type of leads..
they don't burn out like carbon or silicon leads, or break..
I have broken the silicon inside NEW silicon spark plug leads just pulling the lead off the coil...
that is how fragile they are...
these leads are also the cheapest.. lol and the spark plug connectors are made to fit them
#890929
What do you mean by the spark pugs are made to fit them? Cause my spark plugs have the larker ands and they dont screw off
From Dylan
grumble Son of Jim - Creator of Good
2,672 posts · joined Jun 2008 ·
#890943
Hi Dylan use the Bosch W8AC the cap screws off and the thread length is correct,over the years we found that a few makes of plug extended into the cylinder and became clogged with carbon.when they were taken out the thread also came with them. I have a new set of original leads with the connectors and this will rectify your problem if you fit the Bosch plugs. Just pm if you want them. Les
bluebug74 Seriously Crusin Dubber
113 posts · joined Jan 2009 ·
#891289
why not platinum plugs?
Cheers!!
matberry Moderator Go hard or go home
8,114 posts · joined Mar 2006 ·
#891296
I believe NGK have a cut thread where Bosch and Beru have a rolled thread which is more correct for VW heads, also as stated above, preference is for copper leads with the resistive bakerlite plug cap. These are better for the hot environment and most importantly are matched to your 5k ohm distributor rotor to have the correct overall resistance. If using silicone leads, you should use a rotor with zero resistance.
#891305
bluebug74 wrote:why not platinum plugs?
Cheers!!
When I had a Lancer Mitsubishi didn't recommend platinium spark plugs. Suzuki doesn't recommend them either..
and these are 3 or 4 valve per cylinder heads..
#891308
DylanTheDubber wrote:What do you mean by the spark pugs are made to fit them? Cause my spark plugs have the larker ands and they dont screw off
From Dylan
Well My Bosch plugs have the metal caps that come off and My leads fit the caps.. but the caps undo.. lol..
You should buy Your spark plugs from a VW parts shop, as they should sell You the correct plugs...
Matt
I bought a rotor from the USA years ago with no resistor in it.
but haven'e been able to find it... lol
I don't see these for sale in Australia..??
narumi I'll do it tomorrow
138 posts · joined Aug 2011 ·
#892019
I use Magnetti Marelli electronic ignition
that run through copper lead to dizzy
silicone leads to the NGK plugs
I use silicone leads because they're blue
also I use NGK BP5HS or something
because bosch W8AC were obsolete at the shop I went to when I bought it.
AA003 Custom Title Time!
1,189 posts · joined Oct 2011 ·
#892045
68AutoBug wrote:Matt
You get them from a Holden dealer.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!😂
FROSTY Insano Dub Head
744 posts · joined May 2009 ·
#894202
Hey Dylan, did the responses answer your questions? how did you go getting the plugs and leads to fit and function?
Jason
