Skip to content
Aussieveedubbers
V6 into a Baja epic begins !!
Share Share on Facebook Share on X Share on Reddit
Log in to reply
KruizinKombi Seriously Obsessed Cyber Dubber
3,493 posts · joined Aug 2002 ·
#19954
So how quick would Wes's motor be in a 75 kombi? 😀
Kruizin Kol
fatboy Disciple of Kol
603 posts · joined Nov 2002 ·
#19959
Kol - Depends how long he turned his back for 😀😉😀
" Captain Picard, why are there no Indians on the Enterprise ? Don't you need IT Support ? "
Baja Wes V6 Baja Pioneer
3,119 posts · joined Aug 2002 ·
#19998
Well I am hoping that the radiators current position above the gearbox will work ok. And it seems to have no probs. I might put some air scoops on it if I get bored. The radiator is the MX6 one that came with the half cut. It comes with two computer controlled 2 speed thermo fans
For a crust, I am a mechanical engineer.
To get stuff like this approved is easy, just do what the code says and an engineer will approve it.
As for speed in a kombi, go to
http://www.offroadvw.net/tech/calc.htm
and download the cal prog (need excel 2000)
Using that I guess a kombi with a KLZE V6 will do 0-100 in low 6s, and 1/4 mile is mid 14's.
Wes - www.offroadvw.net - 200HP Quad Cam V6 in a VW Baja - with climate control... 🙂
kombi_kid Moderator Good Kid too many projects
124 posts · joined Aug 2002 ·
#20029
hey
that radiator position can obviously only be achieved in a baja right? cause the lift u have on it! where would you recomend as a good spot for a radiator on a bus thats chassis is about 24 cm off the ground?
rhys
weapon Wolfsburg Wizard
439 posts · joined Sep 2005 ·
#491105
fwwwaaaaaaaahhhhhh
seagull Compulsive Aussie Vee Dubber
4,979 posts · joined Dec 2003 ·
#491160
what would be the going rate on one of these motors on there own ? no ecu
can a after market ecu run this ok wes ?
yes I have found one
yes I am looking at puting in some thing
Anthiron The Baja Rejuvenation Begins
4,936 posts · joined Oct 2003 ·
#491297
wow old thread:jesus
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
#491575
yes I know but I found a cheap front cut and what the hell :beer
