Just had another look at it. It's a CSP kit apparently. Check their site ...
http://www.csp-shop.de/cgi-bin/shop2/shop_main.cgi?func=start&wkid=44685830809
only 689 EURO
thats what im after just did the conversion its about $1100 but i dont have the money so looks like ill have to make one
thanks peter your a champ now ive got a base disign i should be able to make one
[Edited on 14/5/2005 by barls]
the chaos project - click me
you just like cos its got horns on it :P
[Edited on 14/5/2005 by pete wood]
maybe mate maybe :P
here on that someone else suggested but its in the same catogory
heres the website
http://www.yunis.de/klaus5/en/Auswahl_en.asp
Two horns better than one eh? 😉
Dare I say it, but for all this trouble you might as well build a decent plenum and EFI it.
Garn, you know you want to....:thumb
pete wood wrote:Two horns better than one eh? 😉
He, he, he - you must have been reading my mind - exactly what I was thinking - Go on - the world will be better for it!
R
40hp, 6V and ...er... slowly making improvements
It's nice to be important, but it's more important to be nice!
Founding member of the Gold Coast Dub Club Inc. 🙂
Have a look on German Look as for some pics.
yeah guys i do but i also want the car back on the road thats a project for after i get it back on the road.
cool steve i will
found this on the german look, looks good
[Edited on 18/5/2005 by barls]
wow, thats clean!
yeah it is im looking at making something similar but we will see how it turns out
If you could make something similar to that and reproduce it for a reasonable cost you'd have no problem selling them.
I'm thinking of making something out of PVC using pod filters and these covers from CB.
http://www.cbperformance.com/catalog.asp?ProductID=563
I've already got the covers as I brought them from Vintage VeeDub many years ago.
I'll see how I go.
im only looking to make one for myself at this stage but if i happen to make something thats easily repoduced i might be convinced to sell them but we will have to see. im going to have to talk to a boat builder about glassing and ideas
hey all just got back from the old mans work shop yesterday and was looking at a stock kombi air box in the bug but will have to wait till i get the engine in to size it up whether it will work or not
good luck, lettuce know how it goes..
That looks ace!
Stuff Kombi, use late-model Commodore or falcon stuff
Pay your debts, CxxT
might work ill see what i can do. im not going out to but something else just so i can cut it up ill give you the tip.
heres one pyro found for me. thanks pyro.
ive got a few sketches going but wont try anything till i get the engine back together so i can make sure it will fit before i start cutting things up
just surfing and found this thread which contains some nice pics in side and out of the csp air box
http://www.shoptalkforums.com/viewtopic.php?t=90311&highlight=
i remembered to take a picture of the other one i made this time i was up there. its made out of a hyundai excel air box its been chopped and had another duct added so it can be run with the twin carbs
ok its been a while since ive posted anything on this. and we have completely changed direction on this one. we are no longer using the kombi air box as a based but are now constructing our own based around a laser filter as its 200mm by 180mm in size and will fit in the area we have cleared next to the alternator. these will run in to 2 ducts that will attach to the carbs. these have come from safari filters. heres a pic of the motor so you can see the space we have to work with.
we haven't decided if the air box will be glass or steel yet and we will decide most likely next time i go up.
just noticed i put up the one with out the carbs or linkage so here it is at a later stage
i hope this is what your after pete
umm, so have you done any more to the air boxes or is it still waiting?
it most like will get done in a couple of weeks mate its hard to do anything when your 4 hrs away
ok finally started on one decided to modify the one that i had. so it was cut down to the just the mounting ring as shown
i then shaped a piece of styrofoam to the shape i desired
then covered the foam with plastic and then started to glass over it
next time i go up ill do some more ie cleaning up and finishing, and hopefully finish it well at least enough to get it on the car so i can get it running
here are the carby tops
the air box now has the inlets for the carbs and is getting closer to being finished now all it needs is to be filled and smoothed so it can be painted
next time i go up ill finish glassing and prep for painting. i might even mount it then
just did a little clean up on some of the glassing, it amazing what you can do with a 7 inch grinder
ill get some more pics when i go up in a week or so
good work - keep the pics coming
here a little teaser of it almost complete and in the engine bay ill have more next week after i get back
