Skip to content
Aussieveedubbers
Turning corners in my 74 beetle
Share Share on Facebook Share on X Share on Reddit
Log in to reply
oval TOFU Bitte, ein Bit!
2,946 posts · joined Jul 2003 ·
#495031
EgeWorks wrote:I saw in the pic that you had an alternator on that motor. Sometimes stock carbs will foul on it. It could be the reason why it is not the stock one on there...
True dat. I'll let you know when you can come pick it up.. i'll u2u u.. on one condition... you help me out with my semaphores!!
blutopless2 DAMSLO
2,457 posts · joined Jan 2004 ·
#495037
of course!... lol... soon as i get em going i'll let you know.
see.... air and water do mix 😉
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
koolkarmakombi enkarmarising
2,078 posts · joined Jun 2003 ·
#495052
You may need to flip the accel. pump lever on the rh side of the carby if it hits the alternator, some need grinding too.
#495054
Its a really easy carb to take off and blow out, comes off a grey motor that one
#495067
Is the carb bolted on securely? I had an instance once when I was taking corners, the carb was loose on the manifold and so leaned out the mixture (to the max) and it hesitated around corners...
blutopless2 DAMSLO
#495086
will check it out... didn't think to check if the carb was loose.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
#495087
it'll be fantastic if it's that simple...
#495110
what a strange carb to put on :alien:alien:alien:alien:alien:alien:alien
has it ever ran well?
blutopless2 DAMSLO
#495114
dont really know... have only had the car for a few weeks... we drove it home from Warrnambool and it stuttered and carried on until we were on the freeway and i just assumed it was coz it was cold... When we started it the next day it was really hard to start and took a few minutes to get it fired up. I had planned to have it checked over for anything obvious that needed fixing etc so put it in to be tuned as well. Car is now easier to start - though it still takes a few minutes. so am now wondering if its the carby at fault for all the things that it is doing.
I will change the carb and see what happens.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
71EJVan Officially Full-On Dubber
352 posts · joined Aug 2005 ·
#495325
An update on mine which confirms the play in the throttle shaft.
Did some tweaking yesterday. Richened the mixture and got reasonable response but high idle. Reduced the idle but responsiveness off the mark suffered when hot. It drives ok but the idle is a little high when you pull up. I might play with the settings some more on the weekend.
Brendan
A VW for everyone!!
1972 1302 German Look
1971 Bay Panel with Subaru EJ20T
1970 Type 3 squareback in progress
1971 Type 3 notchback in progress
68AutoBug Beetle Restorer - Experience over 138\% - YIKES --
11,654 posts · joined Aug 2002 ·
#495375
Brendan,
You could try a little bit of grease on Your carby shafts...
to stop the wear and air leakage....
and make sure the automatic choke works....
if you have cold weather....
Does the manifold heat up OK?
that can cause problems, especially in cold weather...
You may be running everything too rich..??
- Helping keep Air Cooled VWs on the road - location: SCONE in the Upper Hunter Valley - Northern NSW 320 kms NNW of SYDNEY---
#495399
what do the plugs look like?
#495450
Lee,
Manifold preheater is working properly. Good tip on the grease though, some dry lube might assist in the sealing and allow me to tune it better.
I haven't checked the plugs yet. They will be black.
A VW for everyone!!
