Skip to content
Aussieveedubbers
Reubs 58....
Share Share on Facebook Share on X Share on Reddit
Log in to reply
dangerous 23 Windows of Awesome
5,901 posts · joined Jan 2005 ·
#734751
I should mention that the washing of the barrels is at the final assembly time and AFTER all machine work and honing.
Now the head studs are too long to clear the inlet manifold, easilly shortened..lucky it is at trial assembly stage to find this.
Check deck heights:
westi wrote:That's mad Alan.
#734752
Machine piston tops to correct very minor variances and re-balance.
Check piston to valve with light springs:
(camshaft was "dialed in" a couple of degrees adanced long before this check).
And machine heads to make it all sweet.
#734754
Manifolds:
Match port with this:
#734756
The chambers and ports were hand blended and CCed.
Both valves and seats needed to be machined to optimise piston to valve clearance.
New rings were gap filed.
Barrels and heads were then trial fitted.
Spirolocs are a pain, but the best way to retain the pins in the piston.
#734757
Geometry was corrected with 30 thou shims under the rockers and an adjustable pushrod to get the length correct.
This photo shows the pushrod in line with the adjuster at half lift. (.280").
Then make the pushrods the correct length.
These are Manton .058 wall chromoly.
Springs were shimmed and travel of valves set to 1.5mm over valve lift. (only needed one shim of various thickness under each valve spring).
#734758
At final assembly some areas required machining so the valve covers wuld clear:
Just about done:
Ahhh!
Scarab Wolfsburg Wizard
646 posts · joined Jul 2009 ·
#734777
Mate....that is some SERIOUSLY AWESOME work there!! love all the step by step photos.....it gives new inductees to VW's (like me) a great insight into these engines, thanks mate!
I have rebuilt heaps of engines in the past, but never aircooled....the fear of the unknown has been putting me off a little, but your 'in progress' shots have helped to cure that fear, cheers!
cnfabo Custom Title Time!
1,353 posts · joined Apr 2008 ·
#734783
what sought of horses would we expect out of this combo dave ?
humpty Bishop of Volkswagenism
3,336 posts · joined Sep 2002 ·
#734786
My God Dave, you never cease to amaze me... Reub's a lucky lad to have wrangled you into this build!!!! His lil'58 is gonna tramp the Purple car for sure!!! 😀
FUCH your early!
http://www.noh2o.org/
Craig Torrens 6 times Australian, 7 times State Hillclimb Class Champion
8,040 posts · joined Jan 2003 ·
#734896
looks like you had to fix up a lot of poor machining previously done to the heads, that's a pity for Reubs considering he paid good money for them !
Not long now Reubs and you will be kicking arse :cool
bugking Casual Dubber
36 posts · joined Jun 2008 ·
#734911
nice 58 you have there, wish i had the skills to rebuild an engine, or the cash to get it done! Its great to watch how the pros do it.
hellbugged 48's and straight cuts
5,080 posts · joined Apr 2003 ·
#734937
👍..........thanx DB, great read
#734954
Reubs manifolds getting machined flat.
The first job on the new Milling machine!
#735241
so are you just running single valve springs for the cam 'run in' or is that how its going to be ?
#735258
Hi Craig, just single springs to run the cam in.
Then Rueb will have to re-fit the inner springs.
colonel mustard Son of Jim - Creator of Good
2,829 posts · joined Feb 2009 ·
#736618
What is it with you and couriers!
Cant wait to see then new setup in the 58 🙂
#741532
Woot Woot!
Video!! 🙂 Pictures!! 🙂
#741535
are you good for the tool to remove valve springs in situ after run in Reubs???
happy to send mine up if you like.
let me know
#741539
reub-revhead wrote:No vids or pics yet - we've all seen a volksie engine and heard one running?? 😁
have to push mine... can't afford the fuel.
#741598
reub-revhead wrote:The engine lives!! After ensuring there was oil pressure I connected up the fuel pump and hey presto, it started on the first try (just like on TV!). I look forward to driving the car...😵
HUGE THANKS TO DAVE!
Great news mate.... How's she feel?
FUCH your early!
#741652
I knew you would give in to vw peer presssue. hhahaha.
trickysimon 100km/h is only 9 seconds away
1,473 posts · joined Dec 2007 ·
#741658
Sidewinder sounds good aye 😉
#741663
Here is my first youtube vid...
Camo Custom Title Time!
1,936 posts · joined Oct 2007 ·
#741759
Scarab wrote:Mate....that is some SERIOUSLY AWESOME work there!! love all the step by step photos.....it gives new inductees to VW's (like me) a great insight into these engines, thanks mate!
Have to agree with the above and pass on my thanks to Dave for all the great photos, they are a great help and to Reub for spending the money so others can learn 😂
Cheers, Kev
#741916
Taken it for a drive yet Reub!?
matberry Moderator Go hard or go home
8,114 posts · joined Mar 2006 ·
#756665
Great progress mate. Good to see the Haltech system using all those yummy black fittings, should look really nice 🙂. Keen to hear how the cooling system performs up your way, that'll test it out for sure.
#756673
Over 7500-8000 rpm I believe. Never used them myself, although my old 2165 did turn 9000 it also had oil issues and no drains.....
#756685
I'm not a huge fan of the cooling system there (haha, get the pun...), but only because it looks abstract - But, things are designed the way they are for a reason, so i wish you the best of luck with it. 🙂
Intake and ignition look HOT!!!! a fine setup you have going there mate. 1 month goal sounds good!
