Skip to content
Aussieveedubbers
DC build
Share Share on Facebook Share on X Share on Reddit
Log in to reply
matberry Moderator Go hard or go home
8,114 posts · joined Mar 2006 ·
#910699
wow, you been busy 👍
binner Fahrvergnugen
981 posts · joined Jan 2010 ·
#910701
^^^ 8am till 5pm for the last few days ... neighbours are getting compensated due to massive compressor,dust and sanding noise for the last week.
I can safely say this is the final resto I will ever do. no more .........after this is done it's back to spending weekends riding DH.
got a mates buddy coming round to do all my A/C hose set up for a carton......whooo hoooo
now it's on to the easy stuff........ 🤪
71 SQ
Klaus Custom Title Time!
1,439 posts · joined Aug 2004 ·
#910742
what no more welding ? or is aluminium checkerplate filling the big holes 🙂
#910744
F*%K welding.........
I had to get paint on, I'm on a timeframe......wait and see........ 👍
71 SQ
#910748
ok , bog is heavy though in those amounts 😁
#910769
Klaus wrote:ok , bog is heavy though in those amounts 😁
black builders plastic or cling wrap works well I hear. May just finish the rest off with that 😂😂 plus I like the flintstones look in the cab...... 😂
71 SQ
D-train Seriously Crusin Dubber
180 posts · joined Oct 2008 ·
#910775
Forgive me if I'm an idiot, but wouldn't it be better to finish the welding an panels before paint?
66deluxe Custom Title Time!
1,593 posts · joined Aug 2005 ·
#910791
I would love to come round and have a look at my old DC one day?
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
#910843
D-train wrote:Forgive me if I'm an idiot, but wouldn't it be better to finish the welding an panels before paint?
you are not an idiot........
refer to above post.....
don't stress people.... it's all going to be O K .
71 SQ
#910844
66deluxe wrote:I would love to come round and have a look at my old DC one day?
sure ..... you wouldn't like it though. 😂
71 SQ
#911712
Horray!! ...found a rear seat in top shape for the build, I'm excited 🤓
Today was fitting all the body deadener (gotta get it in some tight areas on the doors, took ages) in all about 8 lineal mtrs was added. Finished the crew door lower sill and welded it in, I had to fabricate one at work but forgot to take photos of the bending and folding to form the profiles..🥲
Finished spraying the top half of the doors white and maybe Tues will be painting the lower halves. Al kicked me a early side window glass to use as a template to see if the crew windows are the same size, very , very close so I ordered the fixed window rubbers and will reweld the rubbers to suit. If it looks suss I'll try those popout kits Al has.I like the look of fixed windows in the cewcab so hope it works.
No photos cause it was all pretty boring work today......🙄
71 SQ
h fractals - an ever changing lifestyle
7,671 posts · joined Feb 2005 ·
#911720
valla well gunna be there? well
Barrels www.barrelman.com.au
#911787
are oval window rear window rubber the right size ?
#911808
Klaus wrote:are oval window rear window rubber the right size ?
hrmmmm, not sure. I'm working on the fixed side window seals for split screens. It's a jeep thing oh hang on no it's live n learn thing.......😂
71 SQ
#911809
h wrote:valla well gunna be there? well
What's Valla?.. I doubt it will be ready for that. It's back to uni semester for me so not much time to take off now and work on said vee hickle
EDIT>7200 views what the hell!!!
2 attachments · Log in to view
71 SQ
#911861
...I fitted the doors tonite. Yippie.
71 SQ
#914956
started on the wiring loom today.......good grief man. Looks daunting when it comes out of the box but the E Z wiring kit seems pretty damn good. Once you get it all unrolled and work one section of the bus at a time its pretty cool cucumbers. I decided to wrap it in plastic flexi coil rather than heat shrink.
Such riveting pictures too, don't you think....🙂
3 attachments · Log in to view
71 SQ
#916778
.........so who does machine work on cases in Brisbane? 🙂
71 SQ
#917538
floor is in, rust proofed, welded, sikaflexed (2 tubes worth) undercab, finished the rear window. Gave up on power winder again (just too hard to source,find and wait.) Maybe I will regret it maybe not....
wiring is ........... guh...🤓
fu$%in spring plates are shitting me....
cat pissed on my drop cloth.....
opened up a new bottle of sailor jerry....
71 SQ
#918560
smashed in the brake hard lines,gear linkage,clutch/brake assembly, clutch cable, accelerator linkage and cable. Then tonite hit up the cab with fatmat and checked out how the sub/air con and amp are going to fit. Petrol tank is cleaned cured and given a fresh coat of green 😂
giddyup........
71 SQ
#918586
keep it up! acttion day is nearly here..
you still have time 😉
#918611
Getting there mate. Well done
binner wrote:.........so who does machine work on cases in Brisbane? 🙂
Leon does it, but I'd go to DB (Dangerous on here) at the Goldie. Send him a PM
#918615
h wrote:keep it up! acttion day is nearly here..
Bahhh hahhh, I'll never make that deadline 😂
I'll be there though scouting for some rear stub axles...anyone?...anyone?
71 SQ
#918618
matberry wrote:Getting there mate. Well done
Yeah, It's all the fun bits now........... got a few suprises once it's close to rego time but I'm saving those 😎
I'll PM dangerous and see who it goes...
Cheers Mr Berry.
71 SQ
#919296
had an arvo on the bus
offered up the front beam and put on the steering links.....
it's going to be off the rotisserie soon so if any one needs a rot to suit a bus mine is for sale.......
zapzap
71 SQ
#919889
So, can someone elaborate........... I have green painted torsion bars for the rear and the spring plates (that came with the ute) are to large a diameter to fit the bars. I found another set of spring plates today thinking they would be correct but no, same as first.
Did torsion bars change size (spline #'s) in years or did spring plates change size (splines)?.... I'm about to lose my mind.
thanks in advance peeps....
71 SQ
#919891
spring plates in 68-71 are shorter than 72-79 , and torsion bars are diff dia, splines and trailing arms are also diff in lowlights
#919908
torsion splines = 48 count
spring plate length = 435mm
spring plates = 52 count
I reckon I have the wrong torsion bars, any one?
ohh and my backyard master cly bleed setup,, f@%kn eh!! 😂
thanks
71 SQ
#919925
I might have some, can you measure diameter at each end and in the middle with a vernier caliper?
#919931
Inner = 36.2mm
Outer = 39.3mm
Mid = 28mm
length of rod is 610mm
thanks bloke
71 SQ
