[ Total Views: 682 | Total Replies: 4 | Thread Id: 100413 ]
Author: Subject:  Type 1 manifolds on type 3
MemberFastie
posted on January 8th, 2013 at 07:24 PM
Would like to know if longer straight and offset manifolds used on beetles fit past the type 3 tin. I've got twin DRLA 40s with short manifolds. The problem is I have to remove carbs and manifold to service the spark plugs.. It's to put it bluntly - a bitch of a job.
posted on January 8th, 2013 at 07:55 PM
Probably easier to get a better sparkplug socket. Stahlwille part # 1052 is the best for VW. Adjustable in length, thin wall to get past all but the worst manifolds. I have had an occasional issue on 1 cylinder with the type 3 manifolds, if necessary, carefully clearance the manifold and you won't need to remove them each plug change.
Membergrumble
Mood: happy all the time
posted on January 8th, 2013 at 08:40 PM
And those little wobbly socket extensions are brilliant.
MemberFastie
posted on January 8th, 2013 at 11:50 PM
I have those tools. I'm using empi short manifolds.. Perhaps the cb shorty's provide more clearance as these are a no go.
Memberempi
A.k.a.: Empstar
Mood: thunderous
posted on January 9th, 2013 at 08:50 PM
I know where there are some CB IDF type 3 manifolds locally,
