| [ Total Views: 1294 | Total Replies: 25 | Thread Id: 32828 ] |
Dannyboy
half man , half horse
Threads: 357
Mood: about 2" off the floor
| posted on December 11th, 2004 at 06:49 PM |
Harnesses , legal????
Mmmm more questions. As i plan to take the notch down the strip and to add some safety i'm planning a few mods.
Seat will be fixed (welded) in place and i would like to wear a harness whilst racing. Nothing full on but just something better than the standard
equipment.
My notch is a 65 so how do i go? I have been told many different things and my understanding is this.
Solely they are not legal. If it came with seat belts that what it must retain.For Mr Engineer to be happy it must have the right spreader plates and
nuts and bolts etc and have a cert for when it goes for it's blue / pink slip.
This wouldn't be a problem as alot of harnesses come with either a fixed or eyelet system so it could be taken out when needed.
What do folk do now and how well is my understanding on this?
Any helps good!
Cheers dan
[Edited on 11-12-2004 by dannyboy67]
The Lower Class
68AutoBug
| posted on December 11th, 2004 at 06:54 PM |
there are a lot of illegal equipped cars about then....
All the mounting points would have to be checked and passed by an Engineer.... I would think....
I don't think You will have any problems having them installed... apart from the cost of the Engineer to check them out... some of the buggy guys
may be able to help, they seem to be having things checked all the time by Engineers...
Dannyboy
Threads: 357
| posted on December 11th, 2004 at 07:08 PM |
I've got to get it all done 100% or as best as!. I know this car will be a pull with Mr Plod!
Bolted on my carbs t'day , almost got hard! LOL
( sorry too much info )
Dan:o
The Lower Class
dragbug
Threads: 24
Mood: Building them.....not thinking them!
| posted on December 11th, 2004 at 07:23 PM |
I work in the car parts industry,
We sell the Klippan brand seatbelt.
They do 4 different type's of racing harness's.
All are fully australian and new zealand complianced.
You are legally allowed to run harness's in your vehicle as long as the vehicle does not come fitted with factory inertia seatbelts.
ie.They are allowed to replace old static seatbelts.
This is stated on their brochure.
"O.S.K"
We make it happen!
Oasis
Going alone...
Threads: 77
Mood: Deep
| posted on December 12th, 2004 at 12:02 AM |
Also I think you have to get your seats viewed by an engineer if you're going to do any welding or alterations to the runners.
More Boost
A.k.a.: Rob Critcher
Threads: 6
Mood: Waiting to start the T34 project
| posted on December 13th, 2004 at 06:36 PM |
I had the same question when I was building a car for charity rallies. Engineer stated harnesses were legal but had to be fixed so the shoulder
harness bolted to the body at 45 degrees or less, also rear seat had to be removed and register as a 2 seater. If you weld the seat in the car will be
illegal as the drivers seat must be adjustable for different drivers. When told I would be the only driver the engineer said it didn't matter,
adjustable seat or no ticket.
Dannyboy
Threads: 357
| posted on December 13th, 2004 at 09:43 PM |
After checking the seat rails tonight i saw that there are no plastic runners on them. I'm hoping this was the reason for the seats being a little
lose , i think thats probably the case , fingers crossed. So no fixed seats then. Mmmm , okay. Interested in the harnesses mentioned as my 65 Notch
only has the basic belts in so i'd be able to fit some. Did have it mentioned that the belts would have to be at less than a 45degree angle. If you
mounted it through the cap where the rear seats meet that would be less thgan the 45 and still able to keep the seat. If it means i have to have the
rear seats out and be classed as a 2 seater i may as well fill it with roll cage then.
Dan
The Lower Class
BiX
Threads: 154
| posted on December 14th, 2004 at 07:59 AM |
i think the aim is to keep the shoulder straps as close to slightly down, but close to horozontal. You can always run the eyelets and bolt clip in the
harness once at the track, and run your lap sash shile on the street, this means the belts may not have to be road legal (still have to meet the
racing standards though)
Go hard or go home!!!!
Andy42
Threads: 47
Mood: 2.5t Subi Powered
| posted on December 14th, 2004 at 10:57 AM |
Best off to contact the Transport department or an engineer as far as I can gather in Queensland they must be approved by an engineer or at least the
monting points must comply with the standardsand must have the same style of buckling system as a normal seat belt not the latch or twist type as in
race cars.
vwfastback
Threads: 12
Mood: Ready for Boost.
| posted on December 15th, 2004 at 11:58 AM |
Dan,
Know what you mean about the carbs. Am glad you like 'em.
James C.
Dannyboy
Threads: 357
| posted on December 15th, 2004 at 03:34 PM |
LOL , James you obviously have a carb fetish like myself. I'll send some pics with the 6" ram pipes fitted . VW porn i think!!!!
Dan
The Lower Class
Dannyboy
Threads: 357
| posted on December 15th, 2004 at 03:42 PM |
Okay back to the original topic. Seems then that i'll replace the seat runners tracks which will obviously help matters. The harnesses seem legal but
either way it needs signing off by an engineer weither for rego / legal reasons and racing.
I've got some info coming about the harnesses mentioned before and i'll have a chat to the engineers to what i have to do. I'll also ask about a
cage and whats needed whilst i'm there.
Nothing bloody simple is it! F*#@ !!
Dan:cussing
[Edited on 15-12-2004 by dannyboy67]
The Lower Class
Craig Paton
Threads: 68
Mood: Absolutely Gratefull..!
| posted on December 15th, 2004 at 08:02 PM |
Seatbelts
Hey Dragbug
Do you know of Klippan seatbelts that use the standard mounting points in a '68 beetle?
Thanks Craig |
ruckus
Threads: 165
| posted on May 1st, 2005 at 09:13 PM |
Anyone got any more light to shed on this thread?
Danny did you get any further with your investigations? |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on May 4th, 2005 at 11:11 AM |
I just spoke to a fellow from KCF rallysport ( http://www.kcf-rallysport.com.au ) and asked him if it was legal to run harnesses in my 1963 beetle. He said yes that it
was no problem, but noted that 1974 and newer cars it is not legal (I didn't ask him why or whether there are exclusions to the rule as I am not
interested in cars newer than 1974!!)
Don't take this as gospel, but here in QLD to my knowledge they are legal for my 63!
ruckus
Threads: 165
| posted on May 4th, 2005 at 12:13 PM |
Awesome, thanks Das. That makes me a little hopeful for the '71 then. Anyone know any details for Vic? |
Andy42
Threads: 47
| posted on May 4th, 2005 at 12:36 PM |
From what I can gatther from the engineer helping out with my buggy if you have inertia seat belts you can run harnesses as well but the inertia belts
must stay fitted in the car but this does not mean you have to wear them as you can wear the harness as long as it is adr complient and approved for
its mounting points etc. This is for QLD.
BiX
Threads: 154
| posted on May 4th, 2005 at 02:59 PM |
from what i understand from my research as long as the belts are ADR complient they should be fine if fitted correctly with correct mounts and
engineer checked.
5 or 6 point may not be the legal though.
thats in Qld though.
(I still think its safer to have a 4 point harness than a fixed lap and sash.
gayanne
Threads: 3
Mood: Pure Tubular Adrenalin Subie Power
| posted on May 6th, 2005 at 04:19 PM |
Just make sure harness is aussie made, any thing UK ,USA you will have troubles.After having my car logged book done, my harness in my car was 5years
old and only passed because they were Aussie made.Other makes 3year old wont pass cams scruiteneers report.JVLRacing
DIY-DUB
Threads: 288
| posted on May 9th, 2005 at 09:54 PM |
does this mean fixed bucket seats are illegal?
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on May 9th, 2005 at 10:14 PM |
posted by 1stcarbug
if its still registered as a 4 seater it is
DIY-DUB
Threads: 288
| posted on May 11th, 2005 at 11:15 AM |
so on your next rego you just say to the guy doing your rego/roadworthy that its only a 2 seater it would be ok then?
rallydave
Threads: 0
Mood: busy!!!
| posted on May 14th, 2005 at 10:38 PM |
Hey guys i'm new but have rallied all sorts of things and have a rwc licence here in QLD. Its amazing no-one mentions the COMPLIENCE PLATE on post
ADR vehicles(1971) The fitting of harnesses to a post ADR vehicle is quite illegal in QLD for road use! It MAY be allowed if the owner has an DOT
approved engineer to inspect and privately certify the MODIFICATION on a MODIFICATION plate. Vehicles built pre ADR are largely exempt because no
fixed guidlines were in place for standardization of manufacturers before then.HOWEVER if The rear seating position is compromised on BOTH pre and
post ADR vehicles they should be either removed for road use or MOD plated and used acordingly.
gayanne
Threads: 3
| posted on May 15th, 2005 at 11:40 AM |
Welcome rallydave,it sounds like we would be better of all being cams log booked.JVLRacing
pete wood
| posted on May 16th, 2005 at 07:26 PM |
posted by 1stcarbug
my car has fixed buckets in the front and it's fully engineered for NSW roads.
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on May 17th, 2005 at 09:15 AM |
You can only have fixed buckets in the front of a car if the car is a 4 door or a 2 door with no rear seat. So a beetle with fixed seats would need
the rear seat removed and the seats complianced with a seating capacity change.
Pete, you buggy doesn't have doors, but access to the back is via the top as there is no roof. That is why yours would be OK.
