[ Total Views: 1587 | Total Replies: 11 | Thread Id: 82061 ]
Author: Subject:  suspension ideas 280hp Type 3 IRS
Member72type3wrx
Threads: 61
posted on February 19th, 2010 at 04:50 PM
Hi Guys
Finally got my car running some decent power made just under 280hp at the rears on the last tune.
But my suspension isnt handling the task, I was running a 60 profile tyre and had it rubbing hard under power, now moved to a 50 profile and i have my exhaust get squashed when boost kicks in.
currently im running stock torsion bars (maybe lowered a notch or 2, unsure) with Bilstein shocks, maybe getting tired.
Ive got 100mm clearance between tyre and wheel arch and only 80mm between exhaust and ground.
Looking for the right answer and a cheap one!
been quoted 1300$ for uprated torsion bars and new shocks (seems to pricey)
can i get away with maybe raising my torsion bars (no idea how, seems rather hard or around 500 at a shop to do)
can i regas my struts or get uprated ones?
also i heard i can fit some off road struts or a coil over on the cheap but arnt they really bad??
any help would be greatly appreciated
http://i4.photobucket.com/albums/y134/davidbosa/DSC00622.jpg
http://i4.photobucket.com/albums/y134/davidbosa/DSC00624.jpg
http://i4.photobucket.com/albums/y134/davidbosa/DSC00626.jpg
1972 Type 3 Fast back, RS Turbo 2ltr, VF34/P20,
3" Exhaust, WAIC, Wolf 3D, Sard 540cc's, Swirl pot and VL Fuel pump, Apexi CAI, Custom VW 4spd with straight cut albins 3.87 R&P, stock brakes
MemberSTIDUB
Over it.
Threads: 57
posted on February 19th, 2010 at 05:35 PM
raise it, not that hard really, just gotta measure & hope they they both pop out of the splines on the inners or outers & it should be easy, or...
28mm torsion bars are about $900-1k new, add a decent pair of shocks... i can see where the $1300 comes from :)
or... make it stiff as F*** & put buggy style coil overs on the back as well, theortically works the same as bigger torsions but puts the load on a different area, cheaper than the bars but you get what you pay for, thats the way i see it anyway :)
oh yeah, before you start anything, take it to car lovers, will make working on it alot nicer :tu:
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on February 19th, 2010 at 05:37 PM
Lift the car up on the torsions and fit some new shocks. Have a search on Cal Look or Samba forum cause I'm sure I read something on there the other day about shocks and coilovers for the rear for big power.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on February 19th, 2010 at 08:53 PM
28-30mm torsions....id try rod penrose and put money on them being less than $600!
Install not too ea$y tho, adjustment of the ones you have not too challenging. If you can drive a 280hp vw you should have the ability to be able to adjust the ride height "imo"
Being type 3 front is easily adjusted too...with bigger bars you should be able to keep current height with reduced scrape
posted on February 19th, 2010 at 10:26 PM
Billies dont get shagged too often unless they've been flogged offroad or are really really old so go the bigger bars and check out the shocks when removed. Bigger bars is the obvious place to start with all the extra weight way out back.
Membercuci1986
Threads: 0
posted on February 22nd, 2010 at 05:16 AM
good..
Memberbugzla
Threads: 240
Mood: always happy
posted on February 22nd, 2010 at 06:30 AM
even try air bellows at the back gives u adjust abillity then too they cost around 350 plus making the brakets ......... i know of a few cars up here that use them in other cars for the strip they are a great idea. just my 2 bob
posted on February 23rd, 2010 at 07:44 AM
be worth putting some adjustable spring plates on at the same time as putting the heavier bars in. More $$$, but down the track it will be easier to tune the ride height.
p.s. you might want to think about moving that radiator to the front of the car. They work a lot better there.
Memberdangerous
Mood: 591
posted on February 23rd, 2010 at 08:14 AM
With that amount of torque and weight,
you are going to need to start with the stiffest(?) tortion bar you can.
I'd go for a "short" 30mm but you may be able to get a 31mm.
You may have to get aftermarket spring plates,
but only so that you can get the shortest tortion bar length,
which are not compatable with any of the standard IRS spring plates.
Better shocks are required to control the stiffer 'spring rate'.
If you decide instead, to go for a coil-over style shock, the stock lower mount will need to be re-inforced.
I have had them crack away from the trailing arm, just with the stiff shocks and no springs.
Originally posted by westi
That's mad Alan.
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on February 24th, 2010 at 07:52 AM
Suspension Prices
Larger torsion bars in chinesse $ 220 or SAW $ 330 , Adjustable spring plates to suit all length bars $ 185 , ROD , 02-42729920
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
Memberhellbugged
A.k.a.: Daimo Pell
posted on February 24th, 2010 at 09:46 PM
:tu:........best option
Memberttriebler
Threads: 16
posted on February 25th, 2010 at 09:12 AM
Dave, any info on what sort of reinforcement needs to be done? Extra welds or gussets or more material?
Reversed gears for Subaru transmissions.
Fit a Subaru 5 speed to your rear engined car
www.subarugears.com
[ Queries: 40 ] [ PHP: 16.3% - SQL: 83.7% ]
