[ Total Views: 633 | Total Replies: 10 | Thread Id: 90625 ] |
gizzo
Threads: 7
Mood: a day not laughed is a day not lived
posted on May 24th, 2011 at 10:01 PM |
toe in
what is the preferred toe in on a link pin front end
mines set at 3 ml overall , it steers okay just wondering what other people set theirs at.
66brm
Threads: 4
posted on May 25th, 2011 at 09:38 AM |
Most of the cars I've adjusted were to 2-3mm
vwo60
Threads: 71
Mood: good
posted on May 25th, 2011 at 10:20 AM |
Have you checked the castor, it's just as important as the toe, about 4 degrees, helps self centre the steering and increases straight line stability
gizzo
Threads: 7
posted on May 25th, 2011 at 10:20 PM |
had castor shims in it ,just on 4 degrees,steering was stiff when turning,took them out heaps better nice and light. its not twitchy ,you can steer it
with one hand on the wheel on backroads & tar no worries, it just seems that your constantly playing with the wheel ,instead of relaxing . its a
baja bug ,torsion bars are adjusted a bit higher but not very much , it hasn,t got any bump steer it doesnt dart of the road when you hit
bumps,steering box could be a bit worn but its prety bloody direct about one ml play.
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on May 25th, 2011 at 11:23 PM |
If you are running high profile tyres, then you have more leeway. 3mm is fine.
gizzo
Threads: 7
posted on May 26th, 2011 at 05:49 PM |
no worries, im running 165/15 radials on the front on 6 inch rims
greedy53
Threads: 468
Mood: strung out
posted on May 26th, 2011 at 06:15 PM |
you put ya toe in than you do the hokie pokie and you turn around
vwo60
Threads: 71
Mood: good
posted on May 28th, 2011 at 06:49 AM |
The castor gives you straight line stability, i run 7" x 17" rims on the front with 4 degrees of castor , it is a bit heaver to park the car but it
tracks straight at a 100 KLM's a hour, you can take your hand's of the wheel at that speed and it does not wander
Joel
posted on May 28th, 2011 at 09:31 AM |
Castor is one of those things hardly anyone gives any consideration when lowering a bug.
A standard bug benefits greatly from castor shims and any superbug dropped below about 2.5-3" should have some castor fix bushings.
People just assume VWs handle like crap at high speeds when it just takes a proper setup front end and they ace high speeds.
grumble
Mood: happy all the time
posted on May 28th, 2011 at 08:53 PM |
When I was at the dealership the standard setting was 1/16' to an 1/8th",this was set with a trammel bar always worked well for over 40 years with
no problems.
gizzo
Threads: 7
posted on May 30th, 2011 at 09:57 PM |
thanks for the info everyone,exept one!
