[ Total Views: 526 | Total Replies: 3 | Thread Id: 91770 ]
Author: Subject:  torque converter fluid type 3
Membertweety
Threads: 68
posted on July 25th, 2011 at 02:31 PM
thanks in advance to you guys- you are being a great help to me.
Got my engine out see conversions trike to ea81. and someone had advised me that fluid to the converter is fed from the auto transmission.
While I'm waiting for my adapter I've dropped the auto sump and cleaned the filter. am changing the rear diff to converter seal also. changing the fluid too. was wondering how do I drain the torque converter fluid? there is no drain plug. is a change of fluid necessary in the converter? and can I fit 2 seals in the diff housing converter side. Two seals are advised to be used from trans to diff housing.
Finally how much trouble is it to split the trans from the diff to renew the seals between them and is it worth the effort? eg if it aint broke?
http://www.youtube.com/watch?v=HXwh4z8d66o
SUBARU ea81, VW auto, Detour camper
My ex girlfriend said "its me or a trike". Her big mistake.
Membermackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off :td:
posted on July 25th, 2011 at 04:09 PM
The fluid has to drain out slowly so they use a restricter on the outlet.
Quote of the week
posted on July 25th, 2011 at 05:42 PM
as per above you can also fill with kero or petrol to flush but drain as per above suction or gravity
Membertweety
Threads: 68
posted on July 29th, 2011 at 10:38 AM
great, thank you
