[ Total Views: 782 | Total Replies: 17 | Thread Id: 92706 ]
Author: Subject:  Overheating
Memberclinker42
Threads: 154
posted on September 17th, 2011 at 04:25 PM
Overheating
Hi gents
Ok two weeks ago the car ran perfect. I pulled the engine, fitted new rear main seal, scat 36hp shroud with heater outlets and twin dellortos.
Put the thing back together, quivk tune and just took it for a spin down the highway.
After 20 mins of running started too loose power and oil pressure dropped. Pull over and the engine is frikken hot.
Only thing i havent put on is the heater tubes and the piece of tinware that goes over the muffler and has the two holes for the heater tubes. I blocked of the heater outlets so all the air is going over the heads.
The fan is pushing a lot of air.
What do you guys think.
Memberrose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
posted on September 17th, 2011 at 04:56 PM
well the problem is the missing tinware and engine seal. you need all of it on so that the only air sucked in by the fan is the cool air from the vents in the engine lid or the vents below the rear windscreen.
And it keeps the hot exhaust air from being sucked into the engine bay. Sounds like you've cooked your engine. possibly the rings. hopefully not!!
[img][/img]
posted on September 17th, 2011 at 05:15 PM
There's your problem.
Especially if you have heaterboxes on it still
WIthout the breastplate tin the fan is just sucking up all the hot air off the muffler, cylinder and heads.
And no hoses to the heaterboxes turns them into ovens under the heads.
Blocking off the heater outlets is better than leaving them open but it;s still not the right thing to do.
A hole in the plug about 1" keeps the airflow the same as heaterboxes create, plugging them off completely creates turbulence on one side.
Threads: 732
posted on September 17th, 2011 at 10:25 PM
When your heater is off, air still flows over the heater boxes and the hot air is "waste gated" under the car.
If you have early heater boxes with the aluminium fins - not flowing air over the heater boxes means they will radiat heat
Not such an issue with late boxes that are more just "J" tubes in a box
No beast plate means even more hot air is joing to be sucked in
Just asking - the Dells were jetted up and not lean??
Memberclinker42
Threads: 154
posted on September 17th, 2011 at 10:58 PM
Yes i got em a couple up in the jets, .
no.gif posted on September 18th, 2011 at 01:55 AM
Hi gents
You cooked the engine...
that piece of metal is a must to keep the HOT air under the car and NOT inside the engine bay where the Fan can suck the HOT air ... and that is NOT Good ...
recycling Very Hot air...
same thing would have happened with no fan shroud...
or NO fan belt
It Is that important...
posted on September 18th, 2011 at 09:17 AM
Ha ha ha ha ha ha I've been away for 2 days and misse the best thread EVER.
Clinker, I think Lee is right. Cooking engines when you have all that machinery available to rebuild her can't be all that much of a problem then.....:D
No rear tin will damage your engine. How many times does this need to be discussed. You had all these lessons when you were putting it back together dude.
Maybe some ratio rockers to increase your effective valve duration will make it run cooler?:lol::lol::lol:
Super AdministratorMISS VDUB
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
Mood: Low down and Dirty
posted on September 18th, 2011 at 09:23 AM
What is with people thinking its ok to run a car around without Tinware!!!! :td: We just bought a Beetle from DARWIN that has had some money spent on the performance of the engine, but no bloody tinware:!:
1962 Baja Beetle: "Peanut"
1968 Porsche 912 SWB: "Pip"
1972 Kombi Snail: "The Snail"
2016 Scirocco R: "Rocco"
posted on September 18th, 2011 at 09:29 AM
Had a story recently where a Bris Professional recommended a client run in his engine without the fan shroud......needed another new engine within a week ..... :)
MemberSides
A.k.a.: Dave Sidery
posted on September 18th, 2011 at 10:22 AM
WTF !?!?!
My toys
posted on September 18th, 2011 at 11:07 AM
^^^ Hopefully just a case of one major misunderstanding.
Memberian.mezz
Threads: 280
posted on September 18th, 2011 at 11:22 AM
put a subaru donk in it and a Radiator
problem solved :blush:
:lol::crazy::lol::crazy::lol:
posted on September 18th, 2011 at 12:24 PM
then You can throw the tinware away.... lol
Looked at a beetle at Denman NSW while back...
it was a 1964 standard beetle but it was being driven without any heater hoses or plugs on the fan shroud...
YIKES...
posted on September 18th, 2011 at 04:06 PM
Oh they are out there, usually at the hands of motorbike mechanics who think tinware is dead wieght.
Alot like this guy....
Yes it was actually driven like that :crazy:
Threads: 732
posted on September 18th, 2011 at 04:10 PM
at least the fuel filter is on the right side
Memberzayus
A.k.a.: Bryce
Threads: 26
posted on September 18th, 2011 at 10:12 PM
I like the light weight oil cap!
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on September 18th, 2011 at 10:26 PM
The fencing wire to hold everything that is left in place is what intrigues me. :lol::lol:
From your ole' mate Jeff
Membergrumble
Mood: happy all the time
posted on September 19th, 2011 at 07:37 PM
I spotted a white one on the freeeway near Nabiac this afternoon with a Carerra kit that had the engine lid tied in the fully open position,I couldn't work out what the big black bit was from a distance but as i got closer it became obvious.
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
