| [ Total Views: 3134 | Total Replies: 83 | Thread Id: 74674 ] |
| Pages: 1 2 3 |
Wannavee
| posted on March 2nd, 2009 at 09:18 PM |
Getting major service wednesday.I'd rather someone that knows these things go over it for any potential probs.
Have bought an extinguisher today though!
On that note,i saw a squareback owner at the shops last week and where was his extinguisher? In the boot screwed to the engine cover! WTF?
Not the brightest of ideas ive come across
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 3rd, 2009 at 05:52 AM |
Fire extinguishers are a must I usually carry two, one strapped to the firewall in the cabin and one in the rear cargo area...$30 a pop makes sense tp
protect your car, not forgetting to mention the people/family that ride with you, i replaced the fuel hoses in the engine bay with new stuff and the
hose/tube that comes off the bottom of the fuel tank (taking tank out is easy and recommended if your VW has been sitting for a while, POR 15 have a
tank cleaner and sealer kit that works well and doesn't cost the earth. thanks for the kind words on the shed, it's a bitch to clean if you let it
go...at least i can see the floor. Mick, i've had that feeling several times and not always close to home either have you replaced the fuel line from
tank to engine bay?, basic leather tool roll with spare hoses and clamps in the front luggage area is a must, how are other peoples Type 3's going,
any dramas with repair/resto? I'll be stripping engine this week to the bare case, haven't stripped an engine since the 90's and getting out the
lowering stick is on the cards as well...what shocks should i consider if i'm only dropping the square 2.5 inches? the ones on the square at the
moment are okay but once you get into the sticks and away from the highway they feel limited and harsh
How many is enough?
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 4th, 2009 at 06:26 PM |
found the reason why the ride was shithouse...front bump stops? what front bump stops? and bushes...what are they? Mushed and non existent...oh and
are shocks supposed to rebound? ...well up in the air she goes, it's only money more pics to learn from soon.
How many is enough?
Wannavee
| posted on March 5th, 2009 at 09:43 PM |
Mr scooter,where did you get the clear front indicator lenses fella?
MrScooter
Threads: 24
| posted on March 7th, 2009 at 08:20 PM |
lenses are from classic veedub, you will have to modify them. a little bit of re-drilling the screw holes, and a bit of sanding on the ends to make
them fit..
like most veedub stuff, there's always something to modify and nothing ever works out right first time through.
although wheni lowered the front end, it was too easy and i did it in only 20min, for both sides......
my car is running a bit rich at the mo. you can smell the fuel through the exhaust,, any way to fix this?? like how do i adjust the mixture, with out
throwing out the balance and stuffing the whole thing up?
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 8th, 2009 at 08:23 AM |
I'm having the same dramas Mick, bought a carby kit to rebuild both but i guess you don't want to go that far yet...1 km from home, cruising along
at 110 a big ole BANG! puff of black smoke through the tail pipes and she died COMPLETELY...rolled to a stop and had a few ciggies, ended up jump
starting from second battery...chugged and puffed to life, another puff of black smoke and off she goes, like nothing happened, i'm swapping
generators today, plugs and points...very frustrating...let me know if you have any luck Mick. cheers, Adam
How many is enough?
RATAFIED
Threads: 50
Theme: UltimaBB Psyche Green
Mood: LOL
| posted on March 8th, 2009 at 08:43 AM |
Type3sicko what sort of fuel line did you use and what size im thinking about changing it all aswell
[size=6]RUST IN PEACE[/size]
Klaus
Threads: 100
Mood: Heavily modified
| posted on March 8th, 2009 at 09:11 AM |
good to see hippy 71 that the wagon is about to be regoed sat in my yard for long enough, a very good wagon, motor was out of a 70 000 km 70 fasty,
floor from a 71 wagon that had a side hit early on in its life so minimall rust and body is a 72 which used to be an auto and interior that is pretty
clean and the back seat looks like it had never been sat on. but what it needs is one of these
| Error |
| Error |
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 8th, 2009 at 09:16 AM |
Carl, i used the standard 6mm fuel line, Klaus...when the dollars are in the bank and a non original type 3 lands on my doorstep i'd love to do
that...looks like a full engine bay there.. Cool
How many is enough?
Wannavee
| posted on March 8th, 2009 at 11:19 AM |
Klaus,WTF is that in there?
Dunno bout ya fuel problems guys.My missus hasnt worked on too many vw's so she just said (being the smartass she is) 'Its a fuel problem!
She also mentioned (as a non smartass) that it could be timing??
Cheers for the lenses info scooter
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 8th, 2009 at 06:22 PM |
have cleaned up the carbies a bit to see what they looked like under who knows how many years of neglect, have had a trying weekend with jump starts,
no starts, almost start and then finallly kick over...then stop. Vokda and Kaluha are helping in this matter
| Error |
| Error |
How many is enough?
Klaus
Threads: 100
| posted on March 8th, 2009 at 07:38 PM |
ej20t in a previously unmolessted 68 wagon , goes just a little bit better than stock ha ha. Wagon looks pretty average and is now well known in
area for pissing all over commo and rice body kit boys. one guy was winging to a common friend that its not fair that a shit box vw made him and his
crapadore look bad .
With your carbs check balance bar flex pipes and that the aluminium top half isnt warped leaving a gap between the bottom metal throttle plate .
I've rebuilt many a type 3 carb and always had to flatten out carbs using file or sandpaper on a flat piece of timber or steel.
another reason why i went subi power. Oh and that pump circuit of carbs has the ball bearing unstuck.( under brass threaded plug in float chamber)
| Error |
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 8th, 2009 at 07:46 PM |
Thanks for the pointers Klaus..that subi powered type 3 does look the goods, did you have much trouble with the plumbing.?
How many is enough?
Klaus
Threads: 100
| posted on March 9th, 2009 at 07:22 AM |
not really just alot of them, 7 in total . 2 x rad , 2x heater, 2 x int cooler rad , 1 x rad overflow. Wiring was the most time consuming as the front
cut i go was from the top of the range legacy so cruise ac abs central locking auto and a crap load more, worth it in the end.
| Error |
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 9th, 2009 at 10:00 AM |
looking at that spaghetti juction of wires makes me think i have nothing to bitch about... what modification do you need to slot the subi in the back?
engine mount, bracing etc...looks like a head full but the extra ponies would probably be worth it
How many is enough?
Klaus
Threads: 100
| posted on March 9th, 2009 at 03:17 PM |
basically the motor sits in a cradle using factory subi eng mounts, which bolt up to 10mm plates welded and reinforced at the back and the front is
mounted up near where the irs subframe mounts, the whole cargo floor was cut out to fit water to air intercooler. And theres a brace welded across
there too which has the subi engine stabiliser bar mounted to.
| Error |
| Error |
| Error |
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 9th, 2009 at 10:17 PM |
probably woud'nt be much of this happening too often eh Klaus?
| Error |
| Error |
| Error |
How many is enough?
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 9th, 2009 at 10:31 PM |
you were right about the carbs Klaus.."little bit" of sanding to do, cheers for the info. found a slight crack , though it looks like it's from the
inside out...WTF ?
| Error |
| Error |
| Error |
How many is enough?
Klaus
Threads: 100
| posted on March 10th, 2009 at 08:05 PM |
Plenty of that in the yard with 3 other type 3's ( 64 ,65 notch and 67 fasty) and 3 splitscreens and a lowlight sc, so never a dull moment.
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on March 10th, 2009 at 09:22 PM |
i like the old stuff better than the new stuff..
How many is enough?
Hippy-71
Threads: 9
Mood: Chill-n
| posted on March 12th, 2009 at 12:36 PM |
The ratwgn is definately up for sale ....have other projects that
need funding....so I'm open to realistic offers anyone....12mths rego, new tryes, lowered shocks brakes goes great heaps of power I was supprised how
well it goes !
Will also consider part trades.....
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on April 5th, 2009 at 05:13 PM |
Dirty head, barrells scored and valves cooked
took the heads off the original engine from square, i don't think they have been off EVER! i drove this fairly gently for 2500 klms before i pulled
the engine, not knowing it's complete service history...books stamped up to 90K. spark plugs looked normal, carby manifolds nice and serviceable,
carbies were okay apart from idle screw broken off and float valve stuck.... then i found these catastrophes. how do i remove the wrist pin? holding
piston on? Gently i know but it's in there pretty damn tight? who sells heads or machines them on the Gold coast?
| Error |
| Error |
| Error |
How many is enough?
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on April 5th, 2009 at 05:25 PM |
new barrells and pistons are on the way, just wondering if there is supposed to be burnt oil in the inlet manifold? I'm thinking not, curious as to
why? and what do these numbers signify? 057 0n the left head and 067 on the right...anyone? Thanks, Adam
| Error |
| Error |
| Error |
How many is enough?
Type3Sicko
Threads: 70
Mood: yes thanks
| posted on April 9th, 2009 at 09:24 AM |
I'm after some engine tinware for the square, is there anywhere i can buy complete NOS tinware? or do i need to get a sheetmetal Whizz to make some
up from my mangled mess? Muchas Gracias!
How many is enough?
| Pages: 1 2 3 |
