Skip to content
Aussieveedubbers
Staging brake
Share Share on Facebook Share on X Share on Reddit
Stanley I guess the reward is in the doing of it
4,523 posts · joined Mar 2003 ·
#962096
I'm looking at installing a staging brake prior to Jambo and Warwick for the new engine. The CNC brakes look good but are a bit exy does anyone have any other options? Feel free to show your set up
SuperOwen Fahrvergnugen
868 posts · joined Jan 2009 ·
#962112
Have you already used the handbrake with the ratchet disabled? Cheapest method obviously.
dragvw2180 Officially Full-On Dubber
393 posts · joined May 2006 ·
#962140
Find a master clyinder and caliper from a motorcycle and build your own stand alone setup with a linelock installed on it . Mike McCarthy
1916baja Custom Title Time!
1,990 posts · joined Sep 2007 ·
#962144
Rod has them for about 75 bucks.
FROSTY Insano Dub Head
744 posts · joined May 2009 ·
#962146
I'm needing the same as I don't have a handbrake. I did see rods but haven't called him yet 75 bucks that fits the budget.
#962160
I use the hand brake now for staging but i'm chasing something to lock front wheels for burnout.
hypo-vw Australias 1st 10sec street beetle (Jan 2007) 10.49secs@132m
2,151 posts · joined May 2004 ·
#962169
Stanley wrote:I use the hand brake now for staging but i'm chasing something to lock front wheels for burnout.
We have found using a steering/turning brake is quite effective for use as a staging brake ( both Chris Bolton and Ben Ford use them ) and as it is a dual circuit unit , it can also be plumbed to push the lever in the opposite direction also to lock the front wheels for burnout purposes , if you dont want to install an electric line locker . It would have to be plumbed from a single circuit master cylinder as it only has one inlet fitting and 2 outlet fittings
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
humpty Bishop of Volkswagenism
3,336 posts · joined Sep 2002 ·
#962187
Been using the good old handbrake method for years, but I have upgraded to a steering brake on the new POS pan.... Mine is a total rip off of how Ben's setup is rigged on the VWMA car.... Works pretty well for him from what I have seen.... And I kinda like the idea of having some control over the brakes where you can control the amount of lock you put on.
FUCH your early!
http://www.noh2o.org/
whathaveidone Custom Title Time!
1,559 posts · joined Feb 2010 ·
#962192
My Drawing not good enough for you🙁🙁🙁
#962212
Thanks Wayne, I am only running a single with back brakes only so that will be perfect.
Jason
#962232
whathaveidone wrote:My Drawing not good enough for you🙁🙁🙁
Yes....it was sooooo good it made me hungry for more info. 😂
#962235
Thanks Wayne...I'm running a duel circuit MC so would look at plumbing somthing into the front wheels.
#962678
Hey Stanley, Rod Penrose express mailed two of them today should be here tomorrow. Ill bring yours up to the tnt.
Thanks for sending it out so quick Rod!!
typethreeking Wolfsburg Wizard
621 posts · joined May 2008 ·
#962683
I brought a ksport hydraulic handbrake off eBay, works well
BEING ASPIRATED FEELS GREAT BUT BEING BLOWN TAKES THING TO A WHOLE NEW LEVEL....
