2443TT Fahrvergnugen
962 posts · joined Dec 2002 ·
I'll do the injectors, manifolds + rails and the stainless turbo header and dump pipe for $1000 delivered (i'll pay freight).
I hope you read the info about the header properly. It was made for a wider than stock engine, so to fit another engine you will need to cut and re-weld the pipe from the number 1 cylinder, which is easy to do and best done with the header bolted to the engine and the enging OUT of the car.
Also because the entire header is wrapped in header tape you will need to soak it with water so it doesnt come off in pieces, and even then it might still come apart when unwrapped. If your genuinely interested I'll take more pics of it.
Ian
